RCU Forums - View Single Post - Os ax .46
Thread: Os ax .46
Old 09-20-2021, 02:06 PM
stearman70
stearman70's Avatar
Originally Posted by HansenTsang View Post
Maybe the engine was running well because the piston to cylinder sleeve seal was good from old oil. You cleaning the piston and sleeve may have reduce the compression. Check the idle screw adjustment first and hopefully you can get the idle back. Otherwise compression is the biggest issue regarding a poor idle.
I still think that the problem is the sprea, since when I washed the engine I only removed the carburetor and the rest I did it on the outside without removing even the spark plug. Thank you again.
