Originally Posted by
Walt Thyng
You need to disconnect one BEC by removing the red wire from the servo plug and insulating it. Leaving both in will result in waaaaay to much amperage for the servos AND the receiver (remember BOTH are powered from the BEC).
Walt
Not true, the current that is used is defined by the load and not the other way arround.
In my house i have a 16Amp fuse (at 230V that would be 3680W), but my 10Watt lamp does not blow because the current is defined by the load.
