Originally Posted by
vlcordero
It had a .32 in it so I was looking for a .32 motor, but I cannot swing an 11" prop due to ground clearance. I was ready to move on some parts and realized I may need to downsize the motor but hope to have equal performance as the .32.
You do know that you can down size the blade length by adding a blade? I was just looking at the OS 35 AX and it runs a 10X6 for break in. If you can clear a 9" prop, a 3 blade 9X6 would probably work. If the engine you had was an OS 32, the 35 is a drop in replacement. IF you have your heart set on the electric conversion, ignore my post.
