I saw this earlier this year and was absolutely hooked! Ozzie from
https://www.ozaero.ca/aerocarcontrol-modelismo got me all setup and my Huracan has arrived!
info on the aircraft copied from the website.With its sleek and modern design, the Huracan is an example of true craftsmanship. It comes fully painted with tailpipe, tank and smoke tank, as well as covers for the wings, elevator and rudder. All horns are installed, canopy adjusted, and the gear doors are installed. Ozaero also offers an additional custom painting service for customers in North America.
Weight: 20kg without fuel
Length: 3.009m
Wingspan: 2.671m
Nose to Tailpipe: 2.805m
Suggested Turbine: 210 to 250
Suggested Retracts: Huracan Electron Retract Set ER50's
Assembly Details:
- CG is in front of the wing tube
- 2.5mm down trim for straight and level flight
- Ail 12mm up 15mm down
- Elev 13mm up 15 down
- Flaps 38mm take-off 100mm landing
- Elevator down trim with flaps 6.5mm at full flaps
- Rudder 27mm
- Crow 15 to 20% — it's in the radio
