The problem with aileron to rudder mixing is that the rudder comes back to neutral when you let off of the ailerons. With some airplanes you just need to become more familiar with applying rudder manually for coordinated turns. Aileron differential will also help as without it you are most likely getting some adverse yaw which works against your mix.
