RCU Forums - View Single Post - OS FS .70 Crankshaft bearing fit
Old 10-22-2021, 09:39 AM
1967brutus
Originally Posted by jaka54 View Post
Hi!
C3 or C2 has nothing to do with how they fit in the crank case,or how they fit against the crank, it is the ball play inside the bearings!
I will give you this challenge: Take the same engine, fit a C2 and a C3 bearing as rear bearing, fit the shaft properly in place (all the way home, I mean), then tap the shaft out again and watch the difference between the two bearings. Use heat if you like, or not, does not matter much, as long as you play fair and heat both to the same temp.
I can 100% guarantee that the C2 will come out with the shaft and the C3 will stay in the casing.
