RCU Forums - View Single Post - OS FS .70 Crankshaft bearing fit
Old 10-22-2021, 12:24 PM
jaka54
jaka54's Avatar
I have done so with the WIB bearings I use in my pylon racing engines and there is no difference! Why should it be...The crank should sit firmly in the bearing whether you use a C3, C4 or heaven forbid, a C2 bearing. Itīs the play between the balls and the inner and outer surfaces that dictates if it is a bearing with more play (C3 and C4) compared to a "standard" bearing.
