You can send them to someone like "HemiKiller" Dennis Keegan (
[email protected]), he can enlarge them
to whatever size you need them to be. It can be in a digital form as the attached here so that all of the parts are
enlarged. But you will more than likely need to still make some adjustments when cutting out and assembling
the aircraft, remember everything is enlarged, especially the line thickness, which is where you may encounter
the problem. Also the wood thicknesses may have to be adjusted, otherwise you will end up with a very heavy
aircraft. I have attached a digital file you can download and figure out what size you will need to enlarge to
accommodate the G-62
The plan was downloaded from
https://outerzone.co.uk/plan_details.asp?ID=11032
