Originally Posted by
Ex_Pat_Tanker
It runs ok, but the tracks have stretched badly it needs tensioners to stop it thowing them off in turn. Its powered by a pair of Taigen 4:1 gearboxes (all be it with 360 motors from scrap mato gearboxes due to the lack space), so it has more than enough grunt to push fine dirt around, but the tracks remain the weak point.
If I wanted to spend
a lot of money on it I would fit the aftermarket metal tracks, but I'm not that bothered right now - I spent enough on the actuators for the dozer blade
Thanks for reposting the picks mate!
Those actuators are still not cheap!! but have come down in price a little bit. I plan on using the HL 5.3 board and tx that just came out of my M1A2 (swapped for 7.0) in my version of a Military D10 going to use the channel for barrel elevation for the blade and turret rotation for the ripper. Not sure what motors yet might shell out for some nice gearmotors the Maghomrc sells.....
Cheers Bruce
EDIT: ?? what glue did you use for the styrene to the bruder plastic?? Standard model glue/ CA/ or other??
