Left is the new one. Piston stopper can be done carefully with a screw that is the same threads as a glow plug just be careful! It just needs to kiss the top of the piston. You could round off the end of the bolt so it is smooth. I have also used a wooden dowel that will thread into the hole. You aren't trying to leverage anything against the piston just find TDC.
Sparky
