Originally Posted by
speedracerntrixie
The only way to get glue where it needs to be is to remove the rudder leading edge, glue what you need to but with a waxed piece of 5/32 music wire through the hinge to make sure everything stays aligned. After the repair is done you would just tape the leading edge back in place with some clear tape. Only other real option is order a new rudder but typically not a direct drop in.
Yeah I was a fraid of that. With the color scheme, and everything going on in the world now, might be dang near impossible to get cost effectively--I just might have to open it up. Not terribly hard, just annoying. I'm most concerned about it opening back up though while flying fast. Any caveats you have about ensuring that doesnt happen?
Thanks!
