Starting to suspect that the OS FS91 will give me CG problems,, unless I want to mount a lot of led up front (I dont like ballast)
Briefly checking the CG I will need 150-200 gram up front, (7-8 ounces)
What I understand the CG range is 25mm and I would like to start with forward point.
How and what is the best procedure checking the CG on this model ?
