Originally Posted by
millesm
The only plans are the ones that were uploaded a few posts up - missing the parts templates unfortunately and I have not seen any since the 80's.
Mine is a little busted up after stupidly proving that I could run it on wet grass, hit a bump and smashed up the tail.
I can trace the basic frame shape for you to attempt a rebuild from template if you want.
Crikey, thanks for the rapid reply! Yeah I have them from a few messages up, and have worked out how to zoom in lol. Have also found a local balsa and model supplier so fingers crossed I can source all that is needed. Will post progress and most likely be asking for spec etc as I go cheers
