so what I know fits is the stock switch that comes with a futuba radio seems kinda' generic. I'd assume that as long as it was a simple replacement to that, it' will work fine. I guess you could get your calipers out and measure the bolt hole spacing just to confirm the standard switch is the same as your aftermarket switch. anyway, should be that easy. Without any effort, I'd 100% order the switch you've shown and know it will fit. HOWEVER if you're not comfortable with that, measure the bolt spacing.
