Originally Posted by
ggfalcon36
Do you know how to solder? It's very easy to buy 10 Sub-C Ni-Mh cells (WITH TABS), that might be as high as 6000mAh! But you solder the tabs together in a series string, Positive to Negative. When ordering, buy some large heat shrink tubing, for whatever configuration you want. Add some extra insulation between the areas where the two cells are in close proximity. Most cells are already plastic covered, but a bit extra is a good plan. Fresh off the charger, 10 cells will measure as much as 15 volts, but will settle down to 14V rather quickly. If you do not have a specific "form" in mind, (like 5 cells long, by 2 cells wide).. just about any cordless 14.8 NiMh battery pack would be capable of providing that much capacity. There are many on-line battery suppliers.. not surprisingly... on line. ;-)
NiMH are usually considered to be 1.2V, not 1.5V. They drop from 1.5V very quickly but stay at 1.2V for most of their discharge. I suggest getting two 6 cell packs and put them in series.
Note: I have never seen a 14.8V NiMH cordless battery pack; 14.4 yes but not 14.8. 14.8V is typically a LiPo 4S battery.
