Originally Posted by
rc_heli_flier
Getting mine completed and discovered something today with the tail servos. I went with MKS HV737 servos all around. So far have only hooked up the tail servos with extensions I made myself from 22 G wire bought from Hansen Hobbies. The tail servos jitter when sitting idle, and jitter quite a bit when giving stick input. I have read elsewhere that those servos do this when using long leads, which seems to be the case. Wish I would have know this in advance of buying them. Anyway, what servos are you all using or if you are using the HV737's how did you overcome the jitter?
Thanks.
‘I used those servo’s in a few planes, with as long lead and never had jitter…..what system you ON….?
