Originally Posted by
rc_heli_flier
I'm using a Spektrum ix20 transmitter with an AR9030T rx. I'm using two 2,000mah lipo packs running through an AR Smooth Flite 16 gyro system.
I think it’s a timing issues, the 737 are 333 hz servo but might not like the ar16? Not sure if you have the ability to change the timing, normally on jeti I do auto for all the MKS….but I have run on some build we’re I had to change that for the savox….but that was all jeti stuff….maybe someone will chim in about the ar16…
