Originally Posted by
Bill Adair
H
I recently purchased two Fox 25 r/c engines, and after cleaning them up, and replacing all the screws with new socket head screws, plus removing and re-installing one incorrectly installed cylinder liner - they both run great.
Possibly the easiest starting engines I've ever owned! One flip starts hot or cold seem to be the norm.
Now I'd like to try one or both with a c/l carb, instead of the locked open r/c carbs I'm using. These are the carbs that sit on a flat that is cast into the top of the crankcase nose, and the c/l carb is mounted the same way.
If I can buy one or two c/l carbs cheap that would be great. I'd even appreciate a loaner, just to see if there is any advantage using the c/l carbs.
Any help appreciated.
Bill
Hi…I have a fox 25 cl eng and need the rc carb… still interested in tradiing?…Dan
