Saito FG-14C fuel line
Spec recommends 3mm (.118 ID) fuel line of which I have none available to me. I do have gas large 1/8 (.125) and standard 3/32 (.093) . The dif for the larger line (.007'') is less than the dif of the standard line (.025'') by my calculation, so the obvious choice would be to use the larger line. IS there any reason not to use the larger line and go with the standard (smaller) even tho the dif is greater than recommended by Saito? I know i know, its the minutia that makes this stuff tedious sometimes but you dont know until you know
