Would an "L" bracket work? IIRC, there isn't a bulkhead running the length of the hull where the rudder bracket is mounted so an "L" bracket won't work in the configuration described. For an "L" bracket to work, you would need to attach it to the transom and hull bottom and run it at least a cm past where the screws go through the transom
