Originally Posted by
paulsf86
With all of the Flex retract systems you must do and up/down gear cycle after arming radio. Otherwise the gear will retract while the doors are closing and jam the doors, often burning out the gear door servos. It is only a 1-2 sec up/down retract switch actuation but it must be done.
Not on the Flex Jet Pro, although it can not hurt if you do.
