Originally Posted by
David Jackson
Did the maiden flight on my Voyager today. Just curious, did anyone have an issue with the main wheels that came with their Voyager? I notice the left main wheel on my plane does not rotate freely. Initially thought that the bearing were bad, but that doesn't seem to be the problem.
I have some problems with the tires dropping off the wheels and grinding against the struts, the field solution was to apply the thin ca all around the joint between the tires and wheels, but the best solution is to fill the tires with 3M windshield glue , this is straight black rubber and if you don’t have it go to auto glass shop they have it for sure and just as them to fill the tires with that rubber glue, make sure that you have the wheels with you to seal them together and this will fix the problem
