Originally Posted by
luv2flyrc
Why reverse the pipe? Are you getting a pitch change with throttle? I use a Tams pipe and get some pitch change (can't remember what direction) but, I just mixed it out with a throttle to elevator mix years ago and have never thought about it again.
Mike
I have two Phantoms flying and have helped set up others. With the Tam pipe I set 5 degrees down turbine angle and match Tam pipe to 5 degrees down. No pitch change with throttle at all. Same situation with bent pipe. Set engine level at 0 and measure pipe at rear and move till it is 5 degrees down resulting also in no pitch changes with throttle!!! Then fabricate bulkhead to hold pipe in place.
