Originally Posted by
kevinthoele
Same situation with bent pipe. Set engine level at 0 and measure pipe at rear and move till it is 5 degrees down resulting also in no pitch changes with throttle!!! Then fabricate bulkhead to hold pipe in place.
Okay, then I must eliminate the front 5 deg in "
New Setup", and only have the aft 5 deg left, I think ......
To achieve that, the pipe might hit the upper part of the exit-hole in the fuselage. But I will try and see what happens.
By the way, thank you all for bothering answering my questions.
