I have a couple of questions that I would appreciate knowing what everyone is doing. The manual calls out 2x 3S batteries connected to the EBEC. When I watch Utube videos and builds they all are using 2x 2S batteries connected to the EBEC. What is the correct battery setup? I have two manuals. A small one that came with the plane and a second one from Banana Hobby (also marked Global Jet.club). The manual with the plane shows CG of 168mm and the Banana Hobby manual shows the CG of 178mm. Both provide an identical diagram of the CG which shows the CG at about the midpoint of the turbine access hatch release catch in both manuals. I measured from the leading edge to the midpoint of this release catch and it is in fact 168mm. 178mm would not be as depicted in the Banana Hobby manual. What is the correct CG for the plane? Thanks for any inputs!
