When putting the Mains up against the constructed kit, it shows the design did not accommodate the forward wheel of the mains when retracted into the fuselage. ** Custom Wings – recommend you move Frame 14 design forward to 13, and copy/past Frame 15 design to 14 (will result in extension of EDF engine access hatch by one frame too) **.
Issue with Mains retracting into Frame 14
Clash with Frame 14 - Some work with the Dremel and some custom framing & formers are required....
