Thanks for sharing your flight report and setup Scott!
With 1" throws on the ailerons would you say the roll rate was pretty fast given the size and weight of the jet? Is your 1" throw a lower setting assuming you're using dual rates? After setting up my aileron servos my max travel is +/-30mm (+/-1.18").
