This will be my 1st crack at this. SHould be fun. Going to build a Alchemy Pro. Mostly posting this for two reasons:
1. I need help
2. For future reference and if anyone else wants to do this, they can use this as a guide.
When I purchased the kit, total was 1962.93 which was the Alchemy pro builders kit with the foam cores and the limited edition clear canopy.
Over the weekend, I was at the Houston Katy Pattern Contest, and I received the kit, and all i can say is "AMAZING".
the quality of the kit and the foam is top notch.
To me, seems like this will be quite straightofrward to get done.
I have a few questions and hopefully Bryan will be able to answer these here, when convenient for him.
Going to get started soon on this as well.
For servos, this is what I was thinking, but if anyone else has any suggestions, please chime in: Futaba BLS 171 for elevator and rudder. and the Futaba BLS 173 for the elevators
Now for some pictures:
this was all nicely packed inside the Fuselage. Missing is the rudder, which was also inside the FUSE.
LE view of the rudder. Very high qualite and straight!
TE view of the rudder. THe Rudder was also packed inside the fuselage, covered with protective wrap foam.
