Originally Posted by
FUTABA-RC
Ignition, servo going bad, loose plug cap, broken/frayed plug wires, etc.
borrowing, and want to ask, my spark wire has been close and sometimes on the header pipe. it sits in the open and get prop thrust as cooling on that part.
is there likely to melt the silicone / plastic covering on the spark cables within the metall armored sock that is running outside the spark wires?
my self had a crash due to strange RX inputs today, and think i might be due to just 10min before i lost the spring that goes in to the spark-plug cap.. but reading what you have been writing i started to think if i might have damaged wires from the ignition box also.
Best Regards.
