Originally Posted by
Vincent
Nothing major but i had to make up a new 8mm axle and drill / tap both ends for bolts to secure. Also the SM axles were 7mm so i had to replace those wheel bearings with 8mm type. I found a used set of wheels and brakes a few months ago on rc groups and bought them. I figured eventually i would be using them as the JP set would just not cooperate.
Sounds like a little bit of work getting and fitting the air brakes. I'll probably try going back to the AG63 and see if it will work better again.
