You will probably NOT be happy with the LGC12. I tried the 12, the 13 and finally they came out with the LCG15. I could not get the electric brakes to work effectively on the 12 or the 13. The 15 is a dream for braking. It is easy to program and works like a charm. Once you get the first 15 programmed, you can transfer the program to other planes for a good start, and then tweak it to address differences. I trashed the 12 and gave the 13 away. I have 3 LCG15s. They have the same programming as Electron's GS200. The 15 uses the brakes for steering to a smooth straight stop. I just push the lever on the Txer fully up, and the planes just stop. No skidding! no dancing! Just a smooth straight stop.
