Originally Posted by
Johnny Isaiah Woods
I need help in setting up my LGC12, after trying every way in the book. I use only retract and brake, but the brake
never works.The instruction are the following: (No data terminal, manual push button)
Switch off power, press the button and switch on the power on the receiver. Release button, the blue light will flash
intermittently, one short flash with a long pause between flashes. set the transmitter at the position you want the
gear retracted, push the button and hold until solid blue light, release button, the led will blink 2 short times.
Repeat the procedure for the brake, and steering.
1 blink -> Gear up command
2 blinks -> Gear Down (extended) command
3 blinks -> Brake OFF
4 blinks -> Brake maximum
5 blinks -> Steering servo retracted position
I know it is something simple that I am leaving out or doing, so any help is appreciated. TIA.
Johnny
‘Turn the brake ON, and then gear up…..Try rotating the wheel when the gear is up….if they don’t it’s because when the gear is up brake are disable in these unit….if that’s the case just reverse all 3 gear wire and all will be good…
I don’t have a LG12 but I have a few RB45 (electron but same unit) and they work fine…
