Ok here we go. I built this Tank last year from two different kits, The Academy M60 came as a dual motor wired remote control Tank so it did not take long to get up and running.
The Dragon M60 is a very detailed static model with a manually articulating Dozer blade that you can pose either up or down and so forth. I am not into static models not even a little lol so I mounted the Blade and its parts on the Academy M60.
Here is a short video
It took both of these kits to build this Dozer Tank
This was an expensive venture but worth it.
