Henglong tanks using 6.0 and newer systems can participate in the AIM modern battles just as they have been integrated into the Tamiya type battles in Southern California. Henglong 6.0 quipped tanks only have a factory setting of 6 hits to knock out a tank. Following the Henglong 6.0 battle compliant rules a henglong tank operator will count to 6 to simulate and equal reload time to their hit count.
Where the AIM rules will change for Henglong 6.0 tanks will come to speed settings. In the average free for all battles of mixed generational tanks all Henglong 6.0 and newer equipped tanks must run low power to stay on an even footing with tanks that start fast and slow down as they get hit. The henglong is the same slow speed throughout battle so it starts off going slow but its slow speed is constant and remains faster than the tamiya type tanks as they take hits and slow down, this giving the henglong tank the advantage as the battle progresses.
During Modern AIM battles, Henglong 6.0 and newer equipped Modern Tanks will be allowed to operate on high speed power, while cold war and older tanks will remain using low power speed settings. The Modern Henglong 6.0 tank using a 360 LegoDEI apple will be balanced with the Tamiya type tanks using the 45deg oriented apples and light class settings.
