Originally Posted by
rbxbear44
Anyone have the measurement from the center of Main Gear to back of wing tube? Using the Xicoy CG tool and would love if someone has this measurement!!!
I have the plane assembled on my workbench and I am the only one home, so I would prefer help on this if at all possible!
Please advise.
Thanks!
The problem is each Max is slightly different and depends on where you want the CG in relation to the rear of the tube. I have mine at 20mm aft and my measurement and Jack's measurement was 5mm different with the same CG. I can give you mine but I HIGHLY recommend you get your plane's measurements.
