Mike,
The manual says if I use the jig where it’s supposed to be then it should be about 14” pitch for the 4 blade. It might be a tad bit much for the 7 cylinder.
ok glad to hear your exhaust is doing the same. I figure it’s the direction of the exhaust flow and the oil residue takes the path of least resistance.
so you agree it might be a tad lean, I’ll try that next time I fly it and since I have the prop apart I’ll back off the pitch to gain a few extra rpm.
