Hydraulic Braking System & HobbyWing 12S Combo
FID Racing will upgrade its Voltz to support Hydraulic Braking System and 12S Power System. Beside we'll upgrade the the chassis and tweak it to enhance its strength and stability.
1. Change from arm’s pin from 6mm to 7mm
2. Change the fixing way of front gearbox by fixing it to shock tower, to restrict the vibration
3. Hydraulic Braking System.
4. Upgrade to support 12S system
5. Refine rear shock structure, and improve on its handling
6. Increase swaybar size to 5mm to allay the axis effect
7. Refine the rear triangulation design to enhance strength and stability.
8. New wheel
