Originally Posted by
traxxis1
David I have one more question. The evo came out to 23lbs with batteries and full UAT. Do you think it will fly well with a king tech K100 G2 which has 22lbs of thrust. Planning on putting a bigger engine down the line if it works out.
thank you for your help.
Yes it will be fine .. may need a bit more runway (hopefully not grass) and you don’t need as much flap 80mm should be fine. No crow
it’s a great jet
