Originally Posted by
wattsup
Easy, just install the spinner backplate as usual then the APC prop and finally insert the prop screw and washer then tighten it up. The Himax prop attachment on the 6330 Pro motor is clean, neat and reliable.I agree, it is different than front mounted conversion kit.
So, you think that having only part of the prop hole in contact with the prop shaft will be sufficient?
