Hello, I recently converted my Moki 150 to a CH Ignition. The CH Ignition included an adapter to match the Moki gray plastic connector to the CH Ignition connector. This worked fine but I wanted to go directly from the Moki braided four wires to the CH Ignition connector.
I used the supplied adapter to determine the color coding relation to the Moki wires. The Moki color sequence (starting with the blue coded wire ) goes Red/Black/Brown/White. I'd post pictures but I don't have that privilege .
So essentially I have a new connector end which matches the CH Ignition connector perfectly. The Moki wires are VERY fragile and takes some care is stripping and crimping the pins. The mating pins and connector are available on Hansen Hobbies.
I added some heat shrink tubing to secure the wires and the new connector. Very secure and no more Moki connectors to fail. Hope that helps.
