Originally Posted by
JohnHab
That is impressive. With no means to adjust the length and having to precisely bend the attach points. Excellent work. Are the metal parts Aluminum? Did they bottom out on the center ply when you installed? What did you pin them with?
Nicely done.
Fittings are 2mm aluminum. Yes, they bottom out in their pockets. This is what establishes the proper geometry. That and the equal length cables. I'm pretty surprised it worked out as well as it did! I can say that if you match the fitting bends on the plans - and between the matching fittings - it should all work out automatically.
The miracle of computer design/manufacturing. . . .
