Originally Posted by
1QwkSport2.5r
I use 400 grit silicon carbide wet/dry abrasive with some oil on it. Clean extremely well, and install piston and ring. Use no other coarser grit abrasive than 400. Also, lubricate well!! Make note if the ring is pinned. The ring gap must be located over the pin before installation or you’ll break the ring.)
