Originally Posted by
jvaliensi
You can cut the pipe with sharp scissors. A cut-off wheel will quickly ruin it and tin snips are way over kill.
Utility scissors worked great with a little practice. Thanks.
Bob_B
Fyi the turbine mounting plates are design to be tapped 3 mm for the mounting of the turbine to the plates
Thank you, that's exactly what I did.
