I believe the metal sleeved plastic carbs were on some of the buggy slide carbs... I remember seeing posted somewhere a plastic carb with a sleeved throttle barrel bore... Perry claims their carb bodies are injection molded black reinforced nylon, and with proper clearances between the brass throttle barrel and plastic bore, should not show any wear, not with the oil content in the fuel.
