Question for the masses, when I got my big shipment of Jet-tronic air valves I also ordered some of their air filters. They are designed to keep the moisture out of your valves which can cause them to not function properly. If you have used these what has been your experience and how did you use them? I know most people use them when they add air but I think they are designed to go in your model. I was thinking about using them in my next build and just adding them inline on the fill ports to the air tanks but it can be a failure point. They have changeable filters with a lock system. Thanks
https://www.fb-rc.com/.../air-filter-for-the-air-valves
