Originally Posted by
Oldsalt1
They no longer service Magnums due to lack of parts. Guess I missed the boat on that one.
It really depends on what you're after, as Bert suggested, you can try Just Engines UK.
Remember that Sanye (the manufacturer of Magnum, ASP, SC, etc...) had a thriving business selling knock off engines rather than their own designs, primarily OS.
That may not be an acceptable business practice for some but it has certain advantages in that some genuine compatible OS parts can be used instead of the cloned ones...
So if you need a piston ring for a Magnum 91 RFS (4 stroke) for example, you can get one from a specialist online stores (Gaviscool for example) or use the OS piston ring for the OS FS .91, and That should work just fine.
Off course many other parts can be used. In the example above, piston, crankshaft, etc...
