Originally Posted by
RCFlyerDan
Thanks Kevin! It definitely needs to go aft that far for landing. I like a more neutral flight balanced jet. I just need to figure out what I can move aft without too much work. I wished that I would have plumbed the fuel system to burn the front center tank first. That way the balance moves aft as fuel is burned. I did this on my 1/6th F-16. Burns front tanks first.
once trimmed at this cg no trimming during flight. It feels very solid. I know it seems far back but I started at 310 and kept moving back till 345. Probably could
even go back touch more but I like the way it flys and lands so I’m done with cg moving.
good news about this plane is it flys fine heavy so if you wanted to add some weight to tail it would handle no problem to see if you like further back cg? Then you could figure what gear to move if you wanted weight gone.
anyway enjoy flying it!!!!
