Originally Posted by
daveracerdsh
Help! I just bought a HG 9cc gas motor...no directions as to how the ignition system is supposed to be hooked up...
??? It is pretty self-explanatory???
Plugcap goes to the sparplug, (duh!), then there are three cables on the ignition box.
The 2-wire cable is the power supply and hooks up to any battery suitable to supply a receiver. Red = +, black = -
The black round rubber enshrouded cable goes to the sensor that should be allready mounted on the front of the engine. Cannpot connect wrong.
The flat 3-wire cable shold be labeled "RPM signal output Tachometer" and is left unconnected unless you intend to use some form of RPM measurement.
