Originally Posted by
jvaliensi
I've seen a couple x45 failures due to carbon buildup on the turbine wheel. I think the little engine is sensitive to excessive oil in the fuel. I use kerosene w/ 4% oil. If I was using diesel, I'd try 3% oil.
Kerosene is harder to get compared to diesel, with current pricing kerosene may be cheaper! A x45 uses a 1/2 liter per flight, so a five gallon can goes for some time.
what about the bigger turbines, no longer recommends diesel on those either? I currently run 4% oil, the Power Model Jet Oil. I think I will be leaving the Xicoy brand as far as turbines go and just enjoy their electronics. If the turbines don’t like diesel I can’t see myself using them. I had really looked forward to purchasing another turbine from them. Oh well.
