Originally Posted by
tmac48
Mitch can you remember having any trouble with the alignment of the tip of the wings. Without the sub rear spar extension(F13) it does seem to line up, did you need to sand that part ( F13) so as it angles down enough to line things up?
Don't recall that. I'm pretty sure I glued the trailing edge and wing tip piece together and then just glued it all up. My experience is that you (generally) should not modify any of the CNC parts of the kit to make things fit. The design and execution of the CNC was spot on - unless otherwise noted in this thread.
Edit: You got me thinking, so I went out and took a pic of a wing tip. The structure of the wing pulls the tip bow into a somewhat cambered shape. You don't want to mess with that. Just glue the bow to the trailing edge piece before assembly then build away.
